 Post subject: Recycle Bin on Nexus
PostPosted: Sat Aug 12, 2017 1:12 am
Hello. I think that Recycler is a bit bugged. When I delete the items from Recycle Bin, the icon on Nexus still shows as it's being full for some time before it's cleared. It has delay after I remove everything from Recycler. Sometimes annoying, I always think there's something in Recycler, but it's actually empty, even though it shows something is in.
 Post subject: Re: Recycle Bin on Nexus
PostPosted: Sat Aug 12, 2017 6:58 am
if i remember right its not a bug but a limitation, it takes some time for windows to communicate to nexus that the bin was emptied
PostPosted: Wed Aug 16, 2017 4:22 pm
I see.
PostPosted: Tue Jan 16, 2018 5:22 pm
I am also have this problem and it has nothing to do with syncing with Windows. It's not changed from a full recycle bin at all for several days with nothing being added to the bin.
PostPosted: Tue Jan 16, 2018 5:32 pm
Have you already installed the v18.1 beta?
It fixes an issue with the bin on non-English versions of Windows, and also how long it takes to respond to state changes.
Users browsing this forum: No registered users and 47 guests
