 Post subject: Is extreme support apply its menu sstyle to explorer
PostPosted: Sun Apr 11, 2021 6:54 pm
Hi,
I want to know if I can apply the content menu style
from winstep extreme, because it is so beautiful.
I want this menu style
https://i.imgur.com/CKbyQFz.jpg
to override this
windows explorer
https://i.imgur.com/iP3HYlM.jpg
 Post subject: Re: Is extreme support apply its menu sstyle to explorer
PostPosted: Mon Apr 12, 2021 7:16 am
You want it to apply to the rest of your system?
You'd need a different program for that. That's something Stardock's WindowBlinds can do.
PostPosted: Mon Apr 12, 2021 2:31 pm
However, note that WindowBlinds only *skins* - it doesn't change the actual menus.
Just a volunteer Moderator, not connected to or affiliated with Winstep Software Technologies, and not an official part of customer service though I do try to help when and where I can if my scarce time permits
PostPosted: Tue Apr 13, 2021 12:43 am
Given his question and my answer, that was a curious bit of extra information. He asked for a "style" program and I suggested one.
PostPosted: Tue Apr 13, 2021 2:08 pm
thank you very much,
I will try it,
but it just will be very beautiful, addition,
if winstep extreme, implemented this feature,
because it has a more powerful, styling system.
Users browsing this forum: No registered users and 47 guests
