Board index : Winstep Forums : General Discussion  [ 149 posts ] Go to page Previous  1, 2, 3, 4, 5, 6, 7 ... 10  Next
 Post subject: Re: So, what's next after v26.9 ?
PostPosted: Sun Oct 11, 2026 12:49 pm
PostPosted: Tue Oct 13, 2026 9:30 am
Still working on the Shelf skinning settings section. As previously mentioned, this is monotonous, time-consuming work.
Since the Theme Builder also serves as a theme creation tutorial, each setting needs a clear explanation of what it does, how it works, and how it interacts with other settings. Everything also needs to be organized logically.
I have made some changes to the main Shelf page. As with the Dock section, the pages shown beneath it - and/or their contents - depend on the selected skinning mode.
Shown here is the Body page for Single Bitmaps mode. The equivalent pages for the other two modes still need to be added. The Shelf Body Content page, on the other hand, is shared by all three skinning modes.
The Theme Builder can also be resized vertically, although its width is fixed, and the page content is scrollable. For these screenshots, I have manually extended each page to show all its settings at once.
PostPosted: Wed Oct 14, 2026 6:44 am
I remember Picco14 and BassDudeNZ being somewhat annoyed a while back when they requested new skinning features and I turned them down.
I tried explaining that skinning was a whole universe in itself, and that I was focused at the time on adding new and missing functional features. Eventually I would turn my attention to skinning, and THEN we could discuss expanding its capabilities.
There was a very good reason for this, even if it might not have been obvious at the time. I am running into it right now as I work on the Winstep Theme Builder.
You see, the skinning engine in these applications goes back over a quarter of a century, to the Windows 9x days. Over the years, it naturally evolved to support new possibilities.
In the beginning, there were no transparent PNG images. You relied on BMP images, where a specific “magic pink” color marked transparent pixels. JPGs were unsuitable because their lossy compression could alter that exact color. There was no alpha transparency: a pixel was either fully transparent or fully visible. Irregular window shapes were created using window regions that effectively “poked holes” wherever the magic pink pixels were.
The introduction of GDI+ with Windows XP brought support for PNG images and alpha transparency. This revolutionized what we could accomplish visually, but it also required a MAJOR rewrite of the skinning engine while preserving compatibility with older magic pink themes.
There are now literally hundreds of skinning settings, many added over the years to accommodate particular needs. After all this time, it is impossible to remember every setting, what it does, and how it interacts with everything else.
But to build something like the Winstep Theme Builder, you MUST have a clear mental picture of all of that. Since I haven't worked extensively with many of these settings in years, this basically means going back to kindergarten and learning them all over again.
Fortunately, I have AI to help me. There is something rather ironic about being the creator of these applications and having to ask an AI to explain how parts of them work. I give it the relevant code to examine, and it helps me trace what each setting actually does and how the pieces fit together. Having written the code does not mean I can remember every detail of it decades later.
So building the Theme Builder is already an extremely tedious and time-consuming process, and on top of that I have to spend considerable time rediscovering how the existing skinning engine works.
Every additional skinning option adds another interaction to understand, another setting to explain, and another possibility to account for in the interface. That is why I wanted to tackle skinning as a whole when I could give it my full attention.
As a bonus, all of this means that once I finish the Theme Builder the skinning engine will be fresh in my mind for a while, making this the ideal time for those two hard-to-please gentlemen to ask me for new skinning features. :P
If not, well, at least the Theme Builder should make skinning more accessible to a whole new group of Winstep users.
PostPosted: Wed Oct 14, 2026 8:07 am
Picco14 and BassDudeNZ are talented guys, just like you, Jorge! It is a pity that sometimes there is a misunderstanding between talents.
PostPosted: Wed Oct 14, 2026 5:14 pm
Thanks and I am sure Picco is appreciative of the compliment too, but truthfully, having worked with the best in my field Globally, which is not Artwork, talent is cheap, it is what you do with it that matters.
We do not always misunderstand, sometimes we plainly disagree without recourse. If there is no flexibility it is not uncommon for people to walk away, this is very normal. Skinners are not the end users in some people's minds PPETROFF60. We do not matter in the grand scheme of this application, but we do enable people to see the possibilities of what can be done with it. That said, it is sometimes forgotten that Skinners are also end users and can see a picture many end users and even the developer cannot see, just like anyone who is too close to something.
Ciao
PostPosted: Thu Oct 15, 2026 12:15 am
Shelf tabs? How hard can it be to skin tabs?
Ah-ah! Looks simple, eh? But isn't.
Besides the page below there are three other independent pages dedicated to the Shelf tab settings and bitmaps, nested below the main "Tabs" page: Active Tab, Inactive Tab and Mini-Tabs.
PostPosted: Fri Oct 16, 2026 3:49 pm
Little by little, settings page by settings page, aaaaaaargh the boredom!!!!! :roll:
I might yet split the mini-tabs page in two, Mini-Tabs and Mini-Tabs symbols.
PostPosted: Fri Oct 16, 2026 8:19 pm
Which is what I ended up doing.
PostPosted: Sat Oct 17, 2026 2:50 pm
Added the settings pages for the "Colors and Textures" Shelf skinning mode. The Body Content page is shared between all three modes. I also merged the Mini-Tab and Mini-Tab Symbols pages for this mode, otherwise the Mini-Tab page would have been left with a sad little option all by itself.
Also got rid of those jarring white borders around the different sections. The frame colors now adapt to the UI mode and are much more subtle. If you think that was simply a matter of changing a color, you are sadly mistaken: I had to subclass the frame control, work out the position and width of its title, and then redraw the border over the original white one using the appropriate colors. But I think all that work was worth it!
PostPosted: Sat Oct 17, 2026 5:26 pm
New alternate sets of weather icons, anyone?
PostPosted: Sun Oct 18, 2026 3:05 pm
Given the above, I'm actually thinking of adding a way to easily install and manage additional weather icon sets to complement the two that already ship with the product.
Since "Icon Style" for the weather module simply means a different set of icons, it would become the only module able to have more than two styles.
The currently disabled "Change Icon" button could become a "Manage Icon Sets" button, opening a dialog where you could preview, select, install and remove weather icon sets. The existing button isn't used for the weather module because, unlike other modules, its icons have no separate background image to change.
The preview could look like the images in the previous post, generated on the fly to show all the icons in a set, together with the set's name and author.
Each icon set would include an INI file containing that information, so you could also select a set by name directly from the "Icon Style" combo box.
Likewise, when more than two styles/sets are available, the graphical style selector could have two small arrows at either end, allowing you to scroll through the available sets. The arrows are the only part whose usability still needs a visual experiment, given the limited space to put them.
I also don't think we should overly complicate installing or even creating weather icon sets: a simple ZIP file containing the icons and an INI file should be enough. When importing a set, the application would extract the files into a temporary folder and validate the INI and icons. If validation fails, it would delete that folder and reject the set, otherwise it would move the new set into its proper location.
Something else I've been thinking about for some time: greatly expanding the options for how forecast information is displayed on the desktop weather module.
PostPosted: Sun Oct 18, 2026 11:20 pm
And two more weather icon sets...
PostPosted: Mon Oct 19, 2026 8:27 am
And finally, the skinning settings pages for the early legacy themes that use multiple bitmaps for the Shelf body and tabs (not that you would or should use this to create new shelf themes, but it needs to be there for back compatibility with those early themes).
This completes the Shelf section, so the Winstep Theme Builder can now be used to create both dock and Shelf themes.
Still to come: menus, the taskbar, hotspot buttons, and desktop modules.
PostPosted: Mon Oct 19, 2026 7:28 pm
Enhanced the existing Windows 11 taskbar preview style to change not only the animations but also the appearance, with an Acrylic background, rounded corners, and updated close buttons and selection highlights.
As you can see, I try to intercalate working in the Theme Builder with less boring work lol
PostPosted: Tue Oct 20, 2026 4:18 pm
Hmmm... Not sure if I should tackle NextSTART next or go for the WorkShelf desktop modules first...
Post new topic Reply to topic Board index : Winstep Forums : General Discussion  [ 149 posts ] Go to page Previous  1, 2, 3, 4, 5, 6, 7 ... 10  Next
Users browsing this forum: winstep and 28 guests
