 Post subject: Fast boot problem
PostPosted: Mon Jan 28, 2019 2:11 am
The problem: Whenever you start the system in safe mode the fast boot configuration is lost, so start nexus as administrator to enable it again.
The solution: The nexus service adds this configuration when you start or you create a scheduled task to which you add this setting at system startup.
Why fix this? Several people just as I remove their drivers in safe mode, either manually or by using programs like DDU and as video drivers are released almost 2 times per month this is really problematic.
Users browsing this forum: Google [Bot] and 41 guests
