 Post subject: StartAllBack Nexus blank App/UWP icons
PostPosted: Sun Nov 22, 2026 6:32 am
StartAllBack: Windows apps dragged to Nexus show a blank icon and won't launch
A user reported that dragging an app from StartAllBack's Apps folder onto a Nexus dock created a shortcut with a blank icon that wouldn't launch. The same app worked when dragged from Windows' built-in Applications folder.
If you run into this, press Win + R, type shell:AppsFolder, and press Enter. Then drag the app directly from that window onto your dock.
This report also prompted a small addition for v26.11. The new UWP App submenu under Insert New Item lets you pick an installed Windows app and add it directly to a dock or shelf.
Why does this happen?
The two folders look similar in Explorer, but they belong to different Windows shell namespaces. StartAllBack provides its own Apps folder for its classic Start menu. When you drag an app from that folder, the shell item identifier (PIDL) refers to an item in StartAllBack's namespace. Windows needs to resolve that item through StartAllBack's shell extension before Nexus can retrieve its icon or launch it.
My best guess is that this is a 32-bit vs. 64-bit issue. Nexus is a 32-bit application. If StartAllBack registers only a 64-bit version of the DLL that implements its Apps folder, 64-bit Explorer can load it, but 32-bit Nexus can't. That would explain both symptoms, although I haven't confirmed the exact cause.
Users browsing this forum: Google [Bot] and 101 guests
