Board index : Winstep Forums : General Discussion  [ 237 posts ] Go to page Previous  1 ... 9, 10, 11, 12, 13, 14, 15, 16  Next
 Post subject: Re: So, what's next after v26.9 ?
PostPosted: Mon Nov 09, 2026 3:05 pm
I'll be back on briefly tomorrow.
I do not wish to hold you up so what is your time frame please?
I only come on for 5mins at a time until the new power supply arrives for the other main computer.
Anyway here's the finished corporate theme. I liked your color choices so I based the entire theme on them.
I'll upload when I get the other computer fixed.
Regards
PostPosted: Mon Nov 09, 2026 3:09 pm
Now that beta 4 has been released, we have time. I would simply like to figure out what is going on, don't like to leave issues pending as related code is still fresh in my memory and I have so much on my plate right now I might end up forgetting about them.
Nice! And the best part of that theme is that it was intended from the ground up to be colorized, so the user can basically select any color scheme he likes and it will still look good! Well done, Andrew.
PostPosted: Mon Nov 09, 2026 4:58 pm
Unfortunately, Theme Builder is only available in English. I wanted to try my hand at being a theme creator, BUT... It’s a pity, a real pity. I’ll stick to using ready‑made themes.
PostPosted: Mon Nov 09, 2026 5:25 pm
That is no longer true and you even have Russian as one of the available languages. There was, however, an issue with the Theme Builder and legacy folders that affects anyone who installed a previous version of the Theme Builder.
Here is what I need you to do:
1. First open WorkShelf Preferences.
2. In the About tab, click the "Open Data Folder" button.
3. Make sure your installation opens to C:\ProgramData\Winstep\
4. Assuming it does, go to C:\Users\Public\Public Documents\
5. There should be a Winstep folder inside Public Documents. Delete it.
6. Exit Winstep Xtreme and re-install the beta.
7. Run the Winstep Theme Builder. You should now see all the available languages.
PostPosted: Mon Nov 09, 2026 6:36 pm
For some reason, it didn’t work right away. I completely uninstalled the program. Then I installed the main program and updated it to the latest beta version. Hurray! Everything is working! Jorge, thank you very much for the advice! :lol: :D :)
PostPosted: Mon Nov 09, 2026 7:05 pm
From what I've seen of the (machine made) Portuguese translation, all the translations are pretty "crap", but still better than nothing, I guess.
PostPosted: Mon Nov 09, 2026 7:59 pm
I looked at the file with the Russian translation in Theme Builder. It’s very large, but it can be edited! The main meaning of the translation is clear. Jorge, you did a great job creating Theme Builder. Thank you very much! :D
PostPosted: Mon Nov 09, 2026 10:36 pm
Will you you do me a small favor?
Please open the Aurora Borealis theme in Theme builder.
Open the menu, drag a submenu and make changes to horiz text distance and arrow distance, and a variet of different widths of the menu (buttonA) and click preview and tell me what happens please? Mine does not change. If the preview works I can work with it. Without it I am better off editing config and refreshing as for me it is not working.
PostPosted: Mon Nov 09, 2026 11:29 pm
Andrew, I reproduced the Preview issue with Aurora Borealis. Changing the text offset from 38 to 70 worked, but changing it back to 38 didn't. Theme Builder had written the correct value; NextSTART was still using the cached settings because each Preview uses the same file path. I've fixed the reload, and the fix will be in the next beta, which I'll get out as soon as possible.
I also found a separate issue when importing Aurora Borealis: the color profile had `Colorize=f` instead of `Colorize=False`. The loader doesn't recognize `f` as a Boolean, so it raised a "Type mismatch" error and Theme Builder aborted the import. I've made the loader handle that without aborting.
That's exactly why hand-editing INI files can be risky. `f` looks like obvious shorthand for `False` to a person, but the code expects a specific value. One character was enough to stop the entire theme from importing. The Theme Builder writes those values in the format the applications expect.
Thanks for the Aurora Borealis test case. It gave me a way to reproduce the Preview issue here which, I suspect, is at the root of all your issues with the Theme Builder and NextSTART.
PostPosted: Tue Nov 10, 2026 12:23 am
OK the "f" is on me for being lazy
I will type it out in full from now on(There are a lot of themes I have been lazy with this in) :lol: :lol: :lol:
I am truly looking at this as "How will this affect someone who has never edited a config file before?".
While I know almost without looking after doing it manually for quite a while, and exactly what some changes in a config file will do without looking +/- 5pixels, the average new skinner won't, and will want to see the GUI refresh on their screen.
I think that will solve it without going any further. If everything refreshes in every section (probably worth doing a once-over?), then no need to pursue it anymore I think? :)
PostPosted: Tue Nov 10, 2026 12:33 am
Wait for next beta.
I'm currently pursuing the bug most likely behind the position of your desktop modules getting screwed. Happened to me here too, and I can reproduce it but still don't know exactly the root cause.
PostPosted: Tue Nov 10, 2026 1:56 am
Found it, fixed it! Holy camaroni, this one was a tough nut to crack. It happened because of a race condition when installing and applying a new theme by clicking an .xtreme file.
Under certain conditions a second call would be made by the theme installer why the first call was still being processed. This left the application in an unstable state. This in turn could cause the position of desktop modules to be saved to the wrong theme slot when switching to a different theme, corrupting whatever was there previously.
PostPosted: Tue Nov 10, 2026 2:13 am
George I am sure you'll remember me losing a complete theme and having to do a restore, Well, this has been a very productive process for all of us. A lot of issues that seemed either imaginary or user-based or intermittent have been isolated and will be solved.
- Reminder to add the menu arrow graphics in TB :lol:
PostPosted: Tue Nov 10, 2026 2:16 am
No need, thanks! Added that since you told me about it and will be in the next beta.
PostPosted: Tue Nov 10, 2026 5:19 pm
Thanks - you are meticulous so but it is massive and anything that substantial it is very easy to forget something.
Briefly, would you kindly look in the themes thread and either answer on the thread or PM me kindly? I'd like to do it for everyone not just myself, but I don't wish to step on any toes.
Thank you :)
Post new topic Reply to topic Board index : Winstep Forums : General Discussion  [ 237 posts ] Go to page Previous  1 ... 9, 10, 11, 12, 13, 14, 15, 16  Next
Users browsing this forum: Google [Bot] and 33 guests
