 Post subject: Theme Builder Help
PostPosted: Tue Nov 17, 2026 9:14 pm
Jorge, I need your advice! When trying to create a new theme, two inaccuracies appeared. How do I fix them?
 Post subject: Re: So, what's next after v26.9 ?
PostPosted: Tue Nov 17, 2026 9:20 pm
I know you asked Jorge but I can answer that. This is a skinning thing and it is because you have not selected a startbar
PostPosted: Tue Nov 17, 2026 9:53 pm
Thanks a lot, Andrew! As far as I understand, does this apply to all modules (for example, clock, calendar, weather, etc.)? Do I need to check the boxes when they are turned on?
PostPosted: Tue Nov 17, 2026 10:08 pm
The preview button is your friend
With each, preview with and without the checkboxes until you get the look you want.
There is a fair bit to learn how each part works, and perhaps treat it as a fun learning experience. :)
PostPosted: Tue Nov 17, 2026 10:16 pm
Jorge, I have a question. Why does the theme builder disappear from the desktop when saving new features in a new theme? Need to go to the Winstep folder every time and open the theme builder in a new way.
PostPosted: Tue Nov 17, 2026 10:41 pm
Andrey, I need your advice! For example, there is a picture, but with text. How do I delete the old text and insert my own text, and are there any special programs for this?
PostPosted: Sat Nov 21, 2026 3:06 am
If it is an image and it is displaying text that is not plain text, then it is likely that unless it is the filename e.g. 'image.jpg' then it is Text created in image form in a graphic application as either a vector or raster image. If it is an image, you will need to create another text image using the text you want and replace it.
PostPosted: Thu Nov 26, 2026 4:03 am
The theme builder requires a database with files and images corresponding to specific functions. For example, you can change the taskbar, the Recycle Bin, the clock, the Start menu, Wanda the fish, etc., and then click the “Open” button. You can select an image or another function you like, and it will appear in your new theme. This way, you can create hybrid themes. Otherwise, it will be difficult for an average user to create a new theme, even with the help of the theme builder.
Users browsing this forum: Amazon [Bot] and 36 guests
