 Post subject: Nexus 10.2 Beta 1 released: Nexus with systray support!
PostPosted: Wed Mar 03, 2010 5:23 pm
Nexus is a free dock for the 32 and 64 bit versions of Windows 2000, XP, Vista and Windows 7.
(The screenshot above displays Nexus with icon reflections enabled at 75%, widened separation between icons, the dock background set to 100% transparent and icons set to opaque. The wallpaper can be downloaded from HERE)
The 10.2 beta release, among other things, adds the ability to display the Windows System Tray on the dock and allows new language files to be added or updated, as they become available, via the built-in automatic update manager.
The system tray can be added to a dock by enabling the relevant setting in the Contents section of the Effects tab in Preferences.
IMPORTANT: This beta package is an update and MUST be installed ON TOP of a previous Nexus 10.1 or later installation!
This is a semi-public beta, please do not share the download link below outside this forum. An official release will be made soon.
Users of Winstep Xtreme should NOT download this file: there is a new private beta of Winstep Xtreme available in the Beta forums allowing the system tray to be displayed on docks, shelves and menus.
1 - Download the 10.2 beta from
http://www.winstep.net/nexus-beta.zip
2 - Unzip the file.
3 - Exit all Winstep applications.
4 - Run NexusSetup.exe
Please note that the ability to customize dock System Tray icons will be available in Winstep Xtreme only.
Feedback on the new 10.2 features is extremely welcome.
Users browsing this forum: No registered users and 14 guests
