 Post subject: Where is data stored
PostPosted: Fri Feb 17, 2017 10:26 pm
Where does Nexus store it's data so I back it up in case iI ned to reinstall Windows 10?
 Post subject: Re: Where is data stored
PostPosted: Fri Feb 17, 2017 11:34 pm
in win 7 its C:\Users\Public\Documents\Winstep
i think its the same in win 10
PostPosted: Sat Feb 18, 2017 11:57 am
Actually, it depends what you mean by "data". If you mean, themes et cetera, it's where Seeker said.
If you're talking about settings, docks, positions, effects etc., it's in the registry. The easiest way to back it up is to open "Preferences", go to the "Advanced" tab and... lo and behold, there's a "backup" button!
PostPosted: Sat Feb 18, 2017 12:11 pm
and the default backup folder is in the folder i mentined
Users browsing this forum: Amazon [Bot], Apple [Bot], Bing [Bot], GPT [Bot] and 163 guests
