 Post subject: [solved] Multi monitor bug?
PostPosted: Sat Mar 04, 2017 3:00 pm
Hello, I've put the shelf on my second monitor and applications launched from the shell are always showing in the second monitor. Last position is not saved. I don't have the problem with the dock (on my first monitor).
 Post subject: Re: Multi monitor bug?
PostPosted: Sat Mar 04, 2017 3:07 pm
The Shelf has *absolutely no influence* on where a 3rd party application appears when launched. It's entirely up to the application to decide *where* it appears.
PostPosted: Sat Mar 04, 2017 3:23 pm
Thanks for the quick answer. You are right, I did not make enough tests. Sorry for that.
PostPosted: Sat Mar 04, 2017 3:24 pm
No problem. :)
Users browsing this forum: No registered users and 165 guests
