 Post subject: Weather N/A
PostPosted: Sat May 06, 2017 12:14 am
Midlothian VA - weather temp N/A.
 Post subject: Re: Weather N/A
PostPosted: Sat May 06, 2017 12:55 am
Could be a temporary glitch, weather feeds seem fine here.
How long has it been like that?
PostPosted: Sat May 06, 2017 1:23 am
days...
PostPosted: Sat May 06, 2017 1:34 am
Open the Weather settings panel, please.
What are the Weather.com and METAR codes for that location (perhaps a screenshot would be better)?
Also, have you tried a different location already?
PostPosted: Sat May 06, 2017 4:15 pm
Metar Code is blank. Weather.com Code is USVA0500
Sunset Beach, NC works fine.
PostPosted: Sat May 06, 2017 5:12 pm
Ok, it's only the actual current temperature that is missing.
This is because the weather feed returned for that location is currently returning an empty value (i.e.; it returns <tmp></tmp> , there should be a temperature value inside that field but there isn't).
That's a weather.com problem, unfortunately.
Try finding the METAR code of the airport/location closest to you and type that in into the METAR code field in the Weather settings panel. This way the current weather conditions (including temperature) will be retrieved from NOAA instead of Weather.com.
PostPosted: Sat May 06, 2017 7:00 pm
Thanks!
Users browsing this forum: Amazon [Bot] and 224 guests
