 Post subject: Workshelf Configuration for Advanced Skinning Prob
PostPosted: Sat Jun 09, 2018 3:58 pm
I am trying to use the newer Workshelf Advanced Skinning mode with WsFullBody.*, WsFullTabI.*, WsFullTabA.*, WsFullTabmL.* and WsFullTabmR.* - but what are the correct configurations for this in the *.wsw file? At any rate, I assume that they must be different from the ones for the old nine bitmap format? Or are they the same? Glad for any help, thx.
 Post subject: Re: Workshelf Configuration for Advanced Skinning Prob
PostPosted: Sat Jun 09, 2018 4:18 pm
Did you read THIS already? Might help.
PostPosted: Sat Jun 09, 2018 8:38 pm
Yes, of course, and I've got all the right bitmaps (obviously, as that's how one started out before cutting it all up into nine bitmaps etc. with the old style. And that's where my problem lies - I have the old .wsw configuration, and am not sure if this remains valid or whether I have to add new config entries for the newer style. I'll try comparing a newer style .wsw file from some other theme again, but couldn't quite make sense of it before.
Users browsing this forum: Amazon [Bot] and 184 guests
