 Post subject: Inverted Shelf Problem - Error?
PostPosted: Sun Jun 24, 2018 4:36 pm
I have come up with a problem with an inverted shelf. All the correct (inverted *F.* bitmaps) are there, and the shelf and tabs are all shown correctly in their inverted version - but then, they are just the normal non-inverted bitmaps. But WsHideF.* and WsPrefsF.* are shown upside down as here:
Am I missing some setting/s in *.wsw config file perhaps? It looks to me that Workshelf isn't actually seeing/using the *F.* bitmaps?
N.B. - Tested by reverse-naming all files, i.e., e.g., the real WsHide.* renamed as WsHideF.* and vice versa, etc.
Workshelf is definitely not seeing the *F.* files and just inverting the normal files. So there must be some setting/s in *.wsw that I'm missing.
Can anybody help please?
Users browsing this forum: Amazon [Bot], Google [Bot] and 140 guests
