 Post subject: Change sound device - shorcut?
PostPosted: Wed Feb 24, 2021 10:40 pm
I regularly change my sound output device. Usually toggling between speaker and headphones. There is a nice little utility called Soundswitch ([url][/url]) that makes it easy to change device using a system tray icon or a shortcut key
Is there a way to set up an icon in Nexus that carries out a keyboard shortcut? It would be nice to have it as a single click.
NOTE - Moderated by Moderator, suspicious link removed above, could be spam or worse.
 Post subject: Re: Change sound device - shorcut?
PostPosted: Fri Feb 26, 2021 6:31 pm
justposted or Nexter, can you send me the link via private message so I can check it out, please?
(This is one reason I really like Discourse as it keeps a history of edits.)
AutoHotKey or a similar scripting language can probably do it for you, as well, justposted.
Users browsing this forum: No registered users and 172 guests
