 Post subject: Tray Icon Grouping
PostPosted: Fri Feb 22, 2019 9:18 pm
Hi,
I was following a tutorial and this is the end result for tray system icon that I want to have (they are all displayed as normal size horizontally) (attached)
File comment: Tray
However my tray icons are being grouped together, and I can't seem to find a setting for system tray at all. Would you please help?
Thank you.
 Post subject: Re: Tray Icon Grouping
PostPosted: Fri Feb 22, 2019 9:42 pm
I actually found it.... can't believe I missed the setting in contents..
PostPosted: Sat Feb 23, 2019 7:30 am
Ok so I paid $29 for the ultimate version so I can change the system tray icon...
I tried googling and search but I can't seem to find an icon set anywhere, would you mind helping me in this? I just want to change the battery, wifi, and volume incons since I have the rest hidden. I'd love to keep them dynamic too, especially for the battery
PostPosted: Sat Feb 23, 2019 11:50 am
Have a look inside
C:\Users\Public\Documents\WinStep\Icons\Systray
Users browsing this forum: Amazon [Bot], Majestic-12 [Bot] and 219 guests
