 Post subject: Using mouse over to open a grid stack in a dock
PostPosted: Sat Apr 06, 2019 3:07 pm
I bought Nexus Ultimate some time ago but have only recently begun using it. In experimenting with grid stacks in a dock I noted that a mouse over of the relevant icon opened the stack. However later on after introducing new grid stacks I had to click on it to get it to open. Is there a setting somewhere that I can't now find that enables the mouseover that I observed before?
Any help would be appreciated, Regards, Jeff
 Post subject: Re: Using mouse over to open a grid stack in a dock
PostPosted: Sat Apr 06, 2019 5:58 pm
Grid Stacks (and sub-docks) will open automatically on mouseover if the global 'Open sub-docks on mouseover' setting is enabled (located in Dock/Shelf Properties -> Behavior tab -> Sub-Docks button).
There is currently an exception to this, however, and that is when you have a Grid Stack showing the contents of a folder and the Grid Stack is set to automatically open the folders in that folder also as Grid Stacks (as these are only temporary, created-on-the-fly, Grid Stacks).
Is this what you mean?
Anyway, I changed the code here for the next release so that even those temporary folder Grid Stacks will open automatically on mouseover if the 'Open sub-docks on mouseover' setting is enabled.
PostPosted: Sat Apr 06, 2019 10:34 pm
Yes thank you Jorge. Your advice re the "open sub-docks on mouseover" worked. I just had trouble finding it. Regards, Jeff
PostPosted: Sat Apr 06, 2019 11:56 pm
Well, yeah, the name and location of that setting made sense when there were no Grid Stacks (which are a recent new feature) and only sub-docks existed to open on mouseover, but now... :cry:
PostPosted: Sun Apr 07, 2019 12:24 am
I'm yet to have a bit more of a fiddle with it and massage it to want I want. But I can see that it will work.
PostPosted: Sun Apr 07, 2019 2:39 am
Another question, can I have labels on a dock which sit below the icon without having to point at the icon with the mouse?
PostPosted: Sun Apr 07, 2019 3:08 am
Now that would not be a dock, would it? :wink:
Docks by definition do not have icon labels.
For that you should use either a Shelf or a Drawer, which have other advantages as well (although they do not support the icon magnifying mouseover effect, but support nearly all the other effects).
PostPosted: Sun Apr 07, 2019 11:17 pm
Thanks. I used a drawer and was able to achieve what I wanted.
Users browsing this forum: No registered users and 170 guests
