 Post subject: Disappearing Workshelf....
PostPosted: Sun Jan 20, 2008 7:45 pm
Having made some changes to my dual monitor setup, Workshelf is now on the 'wrong' monitor.
I understand that to move it to the 'right' one, I should undock it then drag it over there.
However, as soon as I undock it, it disappears entirely and doesn't come back till i re-dock it!
Any ideas??
Steve
PostPosted: Sun Jan 20, 2008 8:56 pm
What WorkShelf version are you running? When WorkShelf is docked, you should have a 'Monitor' sub-menu in the left mini-tab context menu. Have you tried using that?
PostPosted: Sun Jan 20, 2008 10:16 pm
You make life so easy Jorge!
Thank You!
Steve
PostPosted: Mon Jan 21, 2008 9:23 am
Hehe, thanks... which doesn't alter the fact that the shelf should check if it is off-screen when you undock it - I'll fix that in the next release. :D
Users browsing this forum: Amazon [Bot], Bing [Bot], Google [Bot] and 128 guests
