 Post subject: original right click context menu style ?
PostPosted: Thu Sep 19, 2019 10:24 am
hello
is it possible to change right click style from skinned style to original windows style in nexus?
original style (when i do right click in desktop):
https://imgur.com/iP3HYlM
nexus style (when i do right click in dock):
https://imgur.com/CKbyQFz
i mean only skin، not included items and if there be a way to even change right click menu to display only windows items، i would be happier
thanks
 Post subject: Re: original right click context menu style ?
PostPosted: Thu Sep 19, 2019 10:47 pm
Since you are running Nexus and not Winstep Xtreme (which would allow you to use any of the hundreds of available themes for the context menus) there are two things you can do:
1. Go to the General tab in Preferences, click the More Options button and disable the 'Use Windows 10 style on balloon tooltips and other items' option.
This will make your right click context menus white with a small transparent border (the default menu theme on Windows 7 systems). This will also affect the appearance of balloon tooltips.
2. In the About tab of Preferences change the GUI to 'Light Mode', which will give you semi-transparent context menus (but will also change the UI, as 'Light Mode' is intended to match Windows 10's new light mode).
PostPosted: Fri Sep 20, 2019 9:04 am
thanks :D
this style is better 8) . but in the future if add an option to only display windows menu items with 100% windows-like skin, would be great.
Users browsing this forum: No registered users and 202 guests
