 Post subject: Cannot drag and drop an application into the dock
PostPosted: Tue Jan 14, 2020 11:48 pm
as title
 Post subject: Re: Cannot drag and drop an application into the dock
PostPosted: Wed Jan 15, 2020 8:01 pm
Devil is in the details, always is. Which, in this case, are absolutely non-existent. :)
1. Where are you dragging the application from?
2. What are you seeing when you try to drop it into the dock? What exactly happens?
3. Have you tried dropping a file in a folder to the dock already to see if that works?
4. If it doesn't, aren't you getting a warning dialog/message about the UAC when you start the Winstep application?
Users browsing this forum: Bing [Bot] and 204 guests
