 Post subject: Associate Taskbar with primary monitor instead of monitor ID
PostPosted: Wed May 13, 2020 5:16 pm
Would it be possible to add a setting that will always show the taskbar on the monitor configured as "Primary", effectively making it appear on the same monitor that would otherwise hold the ordinary taskbar?
My problem is: I use my laptop both at work and at home, with a docking station connected to an external monitor on both places. However, my external monitor at work is numbered 1 by Windows, while the one at home is numbered 2. NextStart seem to remember on which monitor "number" it was last shown, meaning I have to manually move it to the other monitor every time I alternate between home and work. If instead it could just use the "primary" monitor settings like Windows does, there would be no problem.
 Post subject: Re: Associate Taskbar with primary monitor instead of monito
PostPosted: Wed May 13, 2020 5:52 pm
Suggestion taken. The taskbar in NextSTART needs some love in what regards multi-monitor systems.
Users browsing this forum: Amazon [Bot], Google [Bot] and 184 guests
