 Post subject: Nexus "keep Dock visible when pressing WIN+D" not working
PostPosted: Wed May 13, 2020 5:17 pm
Even with "keep this Dock visible when pressing WIN+D (show Desktop)" checked, if I press WIN+D the dock hides. It hides even when I'm in a maximized app and I click on the "Show Desktop" button in the task bar. I'M using ver. 19.2 on Win 10 (1909).
Thanks for the support, I hope there's a solution to this problem!
 Post subject: Re: Nexus "keep Dock visible when pressing WIN+D" not workin
PostPosted: Wed May 13, 2020 5:50 pm
Well, I am not seeing that here, all the objects that are supposed to remain on the screen when you press WIN+D do so. Also using Windows 10 1909.
Anyone else?
Also, are you running any other 3rd party Windows customization software? Is the dock set to auto-hide? Does it make any different turning that off?
PostPosted: Thu May 14, 2020 12:54 am
It works fine for me. Just to be sure, I checked that box, hit OK, used Win+D and it stayed on the screen. Unchecked the box, hit OK, used Win+D and it was hidden. Checked the box again, hit OK, used Win+D and it stayed on the screen.
It's behaving perfectly fine for me.
PostPosted: Thu May 14, 2020 12:57 am
And then I read the question about the NextStart multi-monitor taskbar and wondered if multi-monitor support could make a difference here. I'm a single-monitor user, so I can't test whether the dock is shown or hidden depending on it being on the 1st, 2nd, or 3rd (etc.) monitors.
PostPosted: Thu May 14, 2020 1:11 am
No, just tested that here on a 3 monitor system. Dock remains visible as it should when docked to other monitors and I press WIN+D.
Users browsing this forum: Amazon [Bot], Majestic-12 [Bot] and 169 guests
