 Post subject: Nexus appears when the cursor on windows taskbar
PostPosted: Tue Jul 28, 2020 8:15 pm
Hi. I wanna ask, why my nexus appears when the cursor is on taskbar? how to disable it? it appears to when in game.
 Post subject: Re: Nexus appears when the cursor on windows taskbar
PostPosted: Thu Aug 06, 2020 8:00 pm
If the dock is set to auto-hide, it will activate when you bump the bottom screen edge with your mouse pointer (which might happen while you are hovering the taskbar). What happens if you dock the top screen edge? Then it should activate when you bump the top screen edge.
Anyway, there are plenty of settings to help prevent accidental activations in the Behavior tab -> Activation Settings dialog of Nexus Preferences.
Users browsing this forum: Amazon [Bot], Google [Bot] and 168 guests
