 Post subject: No registration tab
PostPosted: Thu Jul 23, 2020 4:37 pm
Hi, I have bought a key but there is no registration tab.
 Post subject: Re: No registration tab
PostPosted: Thu Jul 23, 2020 7:12 pm
Hi, You should have received an email with the key attached to it. In the email you should find these instructions:
HOW TO REGISTER:
You should have received a Winstep Xtreme License Key attached
to this message. To register your copy of Winstep Xtreme, please
do the following:
1) Save the attachment file XTREME.WSXKEY to a folder
on your hard drive.
DO NOT OPEN the XTREME.WSXKEY attachment in a text editor!!!
Doing so will corrupt the file. Also MAKE SURE the file
was NOT automatically given a .txt extension by your email
reader when it was saved.
If you are using Outlook Express and the attachment is
grayed out, open the Tools menu, select Options, click
on the Security tab and UNCHECK the 'Do not allow
attachments to be saved...' option.
2) Double click the saved XTREME.WSXKEY file.
Your copy of Winstep Xtreme should now be registered!
You can verify a successful registration by opening the About tab of
NextSTART and/or WorkShelf Preferences: the About screen will display
'This software is registered to...' followed by the name you
registered with.
PostPosted: Thu Jul 23, 2020 10:52 pm
Double clicking the file does nothing, sorry
PostPosted: Fri Jul 24, 2020 12:31 am
Sorry, double clicking the file opens it in notepad
wsxkey isn’t recognised as anything else by my operating systen
PostPosted: Fri Jul 24, 2020 6:41 pm
Redownloading Nexus Ultimate solved the issue
PostPosted: Thu Aug 06, 2020 7:53 pm
You were running the free version of Nexus.
Users browsing this forum: Amazon [Bot], Google [Bot] and 168 guests
