 Post subject: Change Nexus Position
PostPosted: Fri Nov 20, 2020 3:00 pm
Hi, how are you? I use Nexus and would like to move it to the far bottom of my screen, but the lowest option is bottom screen edge, but there loads more room beneath that, how can I move it further down?
Many thanks!
 Post subject: Re: Change Nexus Position
PostPosted: Sun Nov 22, 2020 8:44 am
Can you take a screenshot and show us?
(Pro-tip: There's an "attach" feature while you're writing your message and then it lets you embed the picture in your post.)
Users browsing this forum: No registered users and 197 guests
