 Post subject: Calendar module: unable to change month
PostPosted: Fri Jan 01, 2021 7:36 pm
Dear all,
Since a while i can no more switch the month in the calendar.
When I hit the → or ← button in the title row with the month name, the module closes immediately.
What can be the reason for this?
 Post subject: Re: Calendar module: unable to change month
PostPosted: Fri Jan 01, 2021 8:13 pm
After experimenting with settings...
It turns out that 'single click' via Wacom tablet pen creates this effect.
When using the mouse everything is OK...
With the pen I need to use double click function.
There are websites, for example my newspaper sites, in which the table also does not behave, so this is a 'common' problem on my system...
This seems to be a known phenomenum:
https://answers.microsoft.com/en-us/win ... 533bde2f83
PostPosted: Sat Jan 02, 2021 2:01 am
That's great information. Thank you for following up with your own solution.
Users browsing this forum: No registered users and 184 guests
