 Post subject: Suggestion for thumbnail preview window activation
PostPosted: Tue Feb 16, 2021 5:17 pm
Hovering over an icon that represents multiple open windows (usually with the number badge on the icon) will pop-up the preview thumbnails.
Hovering on one of these thumbnails should activate the corresponding window like the Windows taskbar does.
 Post subject: Re: Suggestion for thumbnail preview window activation
PostPosted: Tue Feb 16, 2021 9:03 pm
Under Winstep, hovering over a preview temporarily brings the corresponding window to the front (while hiding any others). A click on the preview will bring the window to the front.
PostPosted: Wed Feb 17, 2021 1:54 pm
Maybe it should perform that way but it does not. Hovering over a preview does nothing.
PostPosted: Wed Feb 17, 2021 5:37 pm
Which programme are you using - Winstep Xtreme, NeXus Ultimate, or Nexus (free version)? I use this from the NextSTART taskbar in Xtreme, it may behave differently in Nexus. I'll try it ASAP.
Users browsing this forum: No registered users and 160 guests
