 Post subject: Nexus causing gaming input lag.
PostPosted: Sat Apr 17, 2021 6:47 pm
Hi, I just found out that Nexus Ultimate is causing a program that I have been having for a while now. Nexus is causing input lag while gaming(mouse movement causing FPS drops). I have had this problem for a while now and finally, I figured it. I went into my task manager and killed one program after another until I came across your program. I can kill the process of Nexus and no more input lag, and I can launch the program and the input lags returns, all without even exiting the game. It’s clear that Nexus is causing this. Hopefully, there is a setting I don’t know of that will fix this problem. I would hate to quit using Nexus over these issues.
i9 9900K
32Gb DRAM
RTX 2080Ti
 Post subject: Re: Nexus causing gaming input lag.
PostPosted: Tue Apr 20, 2021 9:50 am
You can run the program only when necessary so that it does not take up computer resources the rest of the time. This is much more convenient and logical than wasting RAM to keep an unused process running.
Users browsing this forum: No registered users and 175 guests
