 Post subject: download link for 19.4
PostPosted: Mon Mar 22, 2021 3:06 pm
Where can I download Winxtreme 19.4? Can you please send me the download link. Thanks!
 Post subject: Re: download link for 19.4
PostPosted: Mon Mar 22, 2021 4:53 pm
I'm afraid there isn't one. The only downoad link is for the current version, which now is 20.10. You should always keep a backup of your backups of Winstep ;) - the archives for previous versions by default are in C:\Users\Public\Public Documents\ Winstep\Backup\ but I think by default only the last previous version is saved there.
Apologies to Salman Rushdie -
A Four Russian Generals' Welcome to all AI Bots,
the Generals being Generals Sodoff, Buggeroff, Pissoff, and Phuckoff!
PostPosted: Mon Mar 22, 2021 7:26 pm
I dont have install backups there, just shelf and nexstart backup files
PostPosted: Tue Mar 23, 2021 3:05 pm
Hmm, it seems to me there's something very wrong with your installation then. By default, Winstep keeps a backup of all the (current) executables as well in that directory. However, it doesn't keep old ones there. Best practice is to always keep a few generations of the original download archives. Personally, I keep all the previous versions.
Although, that said, I don't even recall - nor have an archive of - Xtreme 19.4. I do have a 19.2 though, date stamped early March 2019, and then later versions.
PostPosted: Tue Mar 23, 2021 3:19 pm
oh, i have the executeables, but not the installer. and i seem to recall that winstep kept a copy of installers too
edit: found that, its in C:\Users\Public\Documents\Winstep\Versions
PostPosted: Wed Mar 24, 2021 1:51 pm
Of course! Forgot about that! And as I suspected, no 19.4, although there is a 19.4 *Beta*.
PostPosted: Sat Apr 24, 2021 8:17 am
venkum wrote:
Where can I download Winxtreme 19.4? Can you please send me theWhatsApp plus Apk download link. Thanks!
Hi I am new here and do you have any link to download this beta version?
PostPosted: Sat Apr 24, 2021 2:59 pm
No there isn't one - it's a pretty old version by now - latest release version is 20.10 - and betas are generally only available to registered Winstep users while that beta is active.
