 Post subject: Nexus Dock is covering windows...
PostPosted: Fri Jun 29, 2018 3:03 pm
Hello. My main and only issue is my Nexus Dock covering all the windows if I set it "On the top". Somehow it was working well before I logged into another Windows account. How can I fix it?
 Post subject: Re: Nexus Dock is covering windows...
PostPosted: Fri Jun 29, 2018 3:29 pm
Settings are individual for each user on your PC, so you likely forgot to copy the same exact configuration.
When you set a dock to be 'always on top', that is exactly what it does: it remains on top of all other windows.
If the dock is docked to a screen edge, you can make it reserve screen space so maximized windows do not cover it (Position tab in Preferences). Alternatively, you can make the dock auto-hide whenever you open a maximized window (Behavior tab in Preferences).
PostPosted: Fri Jun 29, 2018 3:51 pm
I mean, I want it to look like this:
So you see in the screen, my Chrome window is maximized and doesn't cover the areas left and right to the Nexus Dock. I want the bottom clear, only Nexus Dock to be right there. I'm sure I did it somehow and I remember it took me quite long to make this.
And I had it docked to a screen edge all the time. I checked the 3 first options in Position and still does not help.
PS: OK, I've noticed that my bottom of screen is coverd only by Nexus Dock on my first monitor (which I usually turn off because it's the laptop one), the issue is only on the second monitor which I'm currently using all the time.
PS2: I've finally fixed it! Just had to check some options in monitor settings, log out and log in again to my Windows account and it worked! :)
PostPosted: Fri Jun 29, 2018 6:17 pm
Let me guess: you're running Windows 10 and had different DPI settings per monitor.
Yeah, that can throw a wrench in the works. Per-monitor DPI settings are not supported yet.
PostPosted: Thu Apr 22, 2021 1:29 pm
Class, clear answer. More precisely, you cannot formulate it. Not only the docking station, but also many other programs support individual settings for each user of one computer.
PostPosted: Fri Jun 25, 2021 6:40 pm
Hello,
and how to reduce the space between maximized windows and the dock?
Best Regards.
Users browsing this forum: Bing [Bot] and 153 guests
