 Post subject: Start menù disappearing on open
PostPosted: Wed Aug 11, 2021 9:47 am
Hi there,
Went through the latest Windows 10 upgrades this morning and suddendly the Start Menù began acting weird... when I press the icon, the menù pops up for a second and then disappears. If I kill NextSTART process, it comes back to normal behaviour.
Already tried to reset factory settings, but no luck.
Any help would be appreciated.
Thanks!
Baio
 Post subject: Re: Start menù disappearing on open
PostPosted: Wed Aug 11, 2021 1:35 pm
Not sure, but that sounds like its something only Jorge(the one man behind winstep) could answer and he has ben absent for a while now, hopefully not for much longer
PostPosted: Wed Aug 11, 2021 4:07 pm
Thanks for your replay.
I feel I must reinstall the software from scratch... quite annoying anyway...
Baio
PostPosted: Wed Aug 11, 2021 4:37 pm
I'm sorry you're having this trouble. I updated my Windows this morning right before I left for work this morning but did not play with it after the update. Now I'm worried it might be misbehaving when I get home.
If I can remember to, I'll right another reply indicating whether the update messed things up or not.
PostPosted: Thu Aug 12, 2021 2:52 am
No problems for me. NextSTART and the Windows Start Menu are both behaving for me.
PostPosted: Thu Aug 12, 2021 3:17 pm
Thanks guys... don't know why but the problem has disappeared. :)
Baio
EDIT: I can't believe it... this morning the problem has popped out again... :cry:
Random bugs are the worst.
Users browsing this forum: Google [Bot] and 196 guests
