 Post subject: Can't change delay speed for "open sub-menus on mouseover"
PostPosted: Tue Sep 21, 2021 2:54 am
No matter what delay speed I set it to it always reverts back to 250 ms as soon as I click apply.
I also have some questions about the weather module for the dock.
Which weather provider is it using by default?
Are you able to change the weather provider? If I go into Weather Monitor Settings, Advanced, I see there's a url for aviationweather.gov, weather.com, and MSN.
The options for "How often would you like to update weather conditions", if I choose quarter past does that mean it auto-updates every 15 mins or it only updates 15 mins. after the hour?
When I right click the weather icon and click Check Weather it seems like the temperature never changes. Does it actually do anything?
 Post subject: Re: Can't change delay speed for "open sub-menus on mouseove
PostPosted: Tue Sep 21, 2021 4:27 am
I've just checked and the sub-menu delay seems to work Ok on my PC, so not sure what to suggest other than possibly a re-install.
PostPosted: Wed Sep 22, 2021 2:37 am
As regards the weather module, no, provider cannot be (user) changed as far as I'm aware. The quarter past setting means that it will be checked only at a quarter past each hour, etc. Check weather only seems to work when there hasn't been a connection and no check has been made by the module within the last hour.
Users browsing this forum: Bing [Bot], Google [Bot] and 187 guests
