 Post subject: Make Windows Taskbar stay hidden?
PostPosted: Wed Jan 05, 2022 5:44 pm
Newb here... Another question too...
I have my Dock on the bottom. Also, Winstep is replacing the default Windows taskbar. That's all good, and I have the taskbar set to auto-hide. Whenever the mouse cursor touches the bottom of the window though, the Winstep taskbar unhides. Is it possible to make it stay hidden? Or at least make it ignore the mouse?
Thanks.
Steve Kunkel
Winstep Xtreme
Win 10 x64
 Post subject: Re: Make Windows Taskbar stay hidden?
PostPosted: Thu Jan 06, 2022 4:54 am
No, because how would you otherwise bring the taskbar up?
If you are not using the taskbar *at all* an alternative is to disable the NextSTART taskbar (NextSTART Preferences -> Taskbar tab) and use an internal command to hide the Windows taskbar.
PostPosted: Fri Jan 07, 2022 9:28 pm
That makes sense. Thanks!
Steve Kunkel
Winstep Xtreme
Win 10 x64
PostPosted: Sat Jan 08, 2022 1:30 pm
"If you are not using the taskbar *at all* an alternative is to disable the NextSTART taskbar (NextSTART Preferences -> Taskbar tab) and use an internal command to hide the Windows taskbar."
Thats what I do. I also added an icon in the dock to toggle the windows taskbar incase I needed it.
Users browsing this forum: Amazon [Bot], Google [Bot] and 169 guests
