 Post subject: How to open preferences / main dialogue
PostPosted: Thu Feb 03, 2022 10:14 pm
I'm using NextStart to create a custom menu only. I have the tray icon turned off, so that only the menu is visible. How do you suggest getting to the preferences or program main window? Right clicking in my custom menu does not offer the preferences choice.
I was able to go to the Registry and change the program system tray option to enabled, which solved my issue, but there has got to be a better way or do you just suggest to keep the tray icon enabled?
 Post subject: Re: How to open preferences / main dialogue
PostPosted: Fri Feb 04, 2022 9:31 pm
CTRL+F12 :D
Also, double clicking the top edge of your NextSTART menu (where the titlebar would be if the menu had a titlebar) should also open Preferences.
Lot's of ways to skin an old dog. :P
PostPosted: Fri Feb 04, 2022 10:10 pm
Thanks. I see the ctrl F12 option now. Works great.
Users browsing this forum: Amazon [Bot] and 182 guests
