 Post subject: Help needed about "Show running applications in this dock"
PostPosted: Fri Apr 15, 2022 7:51 am
So I need a tad bit of help. About the "Show running applications in this dock".
Is it possible to disable the little window thumbnails on running applications? It looks a bit "wrong" with the way I configured my PC suite. Any help would be appreciated. TIA.
File comment: If I am unclear, I meant disable the little window previews/thumbnails behind the actual icons.
 Post subject: Re: Help needed about "Show running applications in this doc
PostPosted: Fri Apr 15, 2022 10:52 am
Preferences -> Tasks tab -> Advanced button -> Disable "shows icons of running applications as window thumbnails"
PostPosted: Fri Apr 15, 2022 12:47 pm
Neat. Thanks for the help!
Users browsing this forum: Google [Bot], ircus, winstep and 184 guests
