 Post subject: Show Only System Tray Icon
PostPosted: Sun Aug 14, 2022 3:50 pm
Is there a way to only show the Show System Tray icon but not all the items in the system tray on the dock?
 Post subject: Re: Show Only System Tray Icon
PostPosted: Sun Aug 14, 2022 10:15 pm
In the Content tab of the Properties dialog for that dock (or Nexus Preferences if you are running Nexus free) there is a 'Always show all system tray icons' setting.
This setting controls wether the dock shows ALL the icons in the system tray (even the 'hidden' ones) or only those that Windows displays on the taskbar.
As for which system tray icons are 'hidden', you control that via Windows.
This said, under Windows 11 the battery, volume and network system icons must always be visible.
Users browsing this forum: No registered users and 178 guests
