 Post subject: RE: MOVING MULTIPLE DOCKS & OBJECTS
PostPosted: Thu Feb 09, 2023 11:02 am
Greetings! I am a Windstep Addict. That is because I am an 31-year-old techie that still works with clients and has a strong addiction to my computer and how colorful and functional it is for me.
I have one problem and a suggestion.
The problem is that Windstupo Ultimate has more themes than Extreme. I would like to see that changed.
The second suggestion is that there should be a function to allow us to move multiple objects from one location to another simultaneously, Omegle TV Free Random Video Chat including a second connected monitor. Maybe that can be done now, but I have not found the way.
 Post subject: Re: RE: MOVING MULTIPLE DOCKS & OBJECTS
PostPosted: Thu Feb 09, 2023 8:21 pm
The second suggestion is that there should be a function to allow us to move multiple objects from one location to another simultaneously, including a second connected monitor. Maybe that can be done now, but I have not found the way.
If you'd done a search here you would have found that your principal subject had been raised before. Look it up.
As regards the greater amount of themes for Nexus vs. Xtreme, a Nexxus theme is very quick and fairly simple to create, there isn't that much work involved, plus of course Nexus is compatible with the themes from other (defunct) docks. On the other hand, themes for Xtreme are an extremely involved process covering several applications and more besides, such as desktop modules. A well thought-out and designed Xtreme theme is not done in a day and takes a lot of detailed knowledge also.
Users browsing this forum: Google [Bot] and 203 guests
