 Post subject: any way to disable dock control icon?
PostPosted: Tue May 09, 2023 7:09 pm
when the undocked dock is collapsed, a big nexus icon shows up, is there any way to get rid of this? Opening the dock back up again isn't a concern, I have an edge bump set up which works perfectly fine. Any way to permentantly disable the dock control icon, even if I have to mess around on my end?
alternatively, is there a way to disable the feature mentioned in this popup? (this is for a docked dock)
Image (https://ibb.co/PC8BnzY)
 Post subject: Re: any way to disable dock control icon?
PostPosted: Tue May 09, 2023 7:57 pm
A floating dock cannot have the control icon disabled, it is the only means by which to collapse and expand the dock.
As for the second part of your query, explore the Dock Properties to find the setting that suits you.
Users browsing this forum: Amazon [Bot], Google [Bot] and 160 guests
