 Post subject: How to move the deck on a second monitor
PostPosted: Mon Feb 19, 2024 9:35 pm
I want to move my deck to the second monitor and only be visible there. Is this even an option, if yes please tell me how or add it with an update
 Post subject: Re: How to move the deck on a second monitor
PostPosted: Tue Feb 20, 2024 1:39 am
Deck?! What deck? Unless you mean dock - Nexus - you're decidedly in the wrong forum.
PostPosted: Tue Feb 20, 2024 2:05 am
Did you even try opening Preferences and looking for the option there (clue: in the Position tab) ? Also, are you running the free version of Nexus or something else?
PostPosted: Tue Feb 20, 2024 5:50 am
Yes, im running on the free version but as long as I know you can have only 1 deck on the free version, but i want it only on second monitor. How can I do this
 Post subject: Re: How to move the dock on a second monitor
PostPosted: Tue Feb 20, 2024 1:17 pm
Yes, i meant dock, whe are people, we make mistakes.
PostPosted: Tue Feb 20, 2024 5:24 pm
As you've already been told :
PostPosted: Tue Feb 20, 2024 7:19 pm
Open Nexus Preferences, go to the Position tab, make sure 'Dock to screen edge' is enabled (if it isn't you can just drag the dock to your second monitor) then below this setting select a screen edge and right next to it the monitor you want the dock to show up at.
There are several other ways to accomplish the same thing, but this is perhaps the simpler.
Users browsing this forum: Google [Bot] and 176 guests
