 Post subject: Context menus appear under systray overflow popup window
PostPosted: Sun Jul 07, 2024 8:04 pm
As the title states, all context menus appear under the overflow notify popup window. Any way to work around this? Attached an image for context
 Post subject: Re: Context menus appear under systray overflow popup window
PostPosted: Mon Jul 08, 2024 11:01 am
Just to confirm that this is an issue with Nexus, I wrote an AutoHotKey script that activates the Notification Area Window at the mouse cursor position when the script is run:
Code:
#Requires AutoHotkey v2.0
#SingleInstance
Persistent
global avMousePosX, avMousePosY, NotifWidth, NotifHeight
Send "#b{Space}"
Sleep 200
notifyIconOverflowWindowHandle := DllCall("FindWindow","Str","NotifyIconOverflowWindow","Ptr",0)
overflowNotificationAreaHandle := DllCall("FindWindowEx","UInt",notifyIconOverflowWindowHandle, "UInt", 0, "str", "ToolbarWindow32","str", "Overflow Notification Area")
if overflowNotificationAreaHandle
CoordMode "Mouse", "Screen"
MouseGetPos &avMousePosX, &avMousePosY
WinGetPos , , &NotifWidth, &NotifHeight, "ahk_id " . notifyIconOverflowWindowHandle
DllCall("SetWindowPos","UInt",notifyIconOverflowWindowHandle ,"UInt",1,"Int",avMousePosX,"Int",avMousePosY,"Int",400,"Int",300,"UInt",0x0001)
Sleep 200
and the result is as expected, context menus have correct z-order (see attached image)
PostPosted: Wed Jul 24, 2024 12:59 am
Are you running the dock 'always on top' ?
Users browsing this forum: Amazon [Bot], Google [Bot] and 219 guests
