 Post subject: Where I can find the widget setting?
PostPosted: Thu Mar 06, 2025 11:17 pm
Hi, I have a hard time to find the widget setting, can you tell me where I can find it? Thanks
 Post subject: Re: Where I can find the widget setting?
PostPosted: Fri Mar 07, 2025 3:25 am
Right click the widget\module. A context menu should pop up. In that context menu one of the options allows you to access the settings for that particular widget.
In Preferences there is also a tab dedicated to the Modules\Widgets.
Users browsing this forum: Amazon [Bot], Google [Bot] and 181 guests
