 Post subject: Bring Dock Forward command
PostPosted: Sun Apr 13, 2025 5:47 am
There is a Bring Workshelf Forward command. Can you provide a similar command for Dock (Bring Dock Forward)? Sometimes no matter how long I have the mouse on the edge the dock does not show.
Also, can you provide capability to assign keyboard shortcuts for both of these commands "Bring Workshelf Forward" and "Bring Dock Forward". Keyboard shortcuts can be assigned to all (or maybe many) other commands except for these commands.
thanks.
 Post subject: Re: Bring Dock Forward command
PostPosted: Sun Apr 13, 2025 11:08 am
Not really. The 'Bring WorkShelf Forward" IC simply brings all open WorkShelf objects to the foreground, it does not activate them (i.e. it does not expand the shelf, etc)
What I did was add another internal command, "Activate All". This will expand all open shelves and drawers, unhide all docks, and show all open desktop modules if currently hidden. It will also bring them all to the foreground like "Bring WorkShelf forward" does.
thanks.
Not sure I get you? If you add one of these ICs to a dock, you can add a hotkey by right clicking the IC and selecting 'Dock Entry Properties'. This hotkey will work even if the dock is hidden.
Users browsing this forum: Amazon [Bot], Google [Bot] and 246 guests
