 Post subject: Newb question
PostPosted: Wed Jun 25, 2025 7:33 am
So weekend hit, curled webcamporn.online chill sub-channel hosting blonde gamer streaming Overwatch porn medal speedruns. Her hands superglue-taped dual vibes under pants, triggered every headshot for fifty bucks worth moan points. Chat command says !poggers she screams Pika TakeIt and quits round five cock dangling outta headphones. Still cheesing victory after three hours later when vid reposts best better than any sex on cams compilation.
https://webcamporn.online/video/20021/s ... -na-sayte/
https://pornlive.fun/video/16005/he-cum ... -in-pussy/
Back on pornlive.fun blackout monday, spaniard chic almost slice nut while shaving hedge-watch kickflip. Someone yelled "money shot kill cam" chat rolling standing counts. leans in lens whisper "octopus ink bonus round?" then squirts piss into martini glass. Beats no Nut november speedrun!!! Time stamp remain sticky like battle-earned sticker your tech neck knows immorta forever. Resort to inhibition zero ratios yolo cheers.
https://realwebcamporn.com/video/skinny ... on-webcam/
Side filed bookmark realwebcamporn.com offers after-work steady drought cure. Brunette with double f'd nipple clamps mirror squat grinding thighs to uber fares. Chat guides split-screen bros quiz time trivia "guess cum distance" pixel ruler active lol. She surged slapshots coin bundles worth three weeks lunch man. I on the other hand regret not bringing food was dying starve clacka signing off subscriber feedporn edition snacks pending.
 Post subject: Re: Newb question
PostPosted: Wed Jun 25, 2025 10:13 am
Aristel wrote:
Currently, I get a bubble which gives some extra information about the app with a Title, company, file version, file size etc.Any way to completely disable this?
I assume you are running the free version of Nexus. In that case:
Preferences -> Behavior tab -> More Options button -> Show balloon information tooltips...
Aristel wrote:
Also, I have Nexus dock completely take over from windows task bar, but one feature I used very regularly was the click in the bottom right hand corner of the screen to show desktop. Is there any similar function for this with Nexus? As I have completely disabled my Windows task bar.
You can add a 'Show Desktop' Internal Command to the dock.
Right click the dock -> Insert New Dock Item -> Internal Command -> Desktop -> Show Desktop
You can also add a hotkey in the Item Properties dialog to execute the item via the keyboard (but, of course, pressing WIN + D would have the same effect).
If you were running Winstep Xtreme you would be able to use the "hotspots" feature of NextSTART to do this via a screen corner bump with the mouse pointer.
Aristel wrote:
Is there any way to enable the usual Windows 10 option when right clicking on an icon in the dock. So far, I have managed to make it look very similar to the Windows 10 menu, but I'd just like it to be exactly the same with fewer options.
I assume you mean in terms of content.
Some options in the right click menu are needed to manage that item in the dock, most others (e.g. Send to, Open With) are retrieved from the extended Explorer context menu itself.
If you want fewer options (only the basic needed by Nexus to manage the item) then
Preferences -> Behavior tab -> change "Show full right-click context menu options" to "Never". You can still press the SHIFT key while right clicking an item in the dock to get the full menu.
If you (also) mean aesthetically, then the NextSTART component of Winstep Xtreme would allow you to use different themes/visuals for the right click context menus. Winstep Xtreme has its own version of the Windows taskbar, but since you do not want that, with Winstep applications being completely modular you could simply turn the NextSTART taskbar off (and still take advantage of the hotspots, user defined menus and menu themes featured in NextSTART).
Users browsing this forum: No registered users and 177 guests
