 Post subject: eject usb device
PostPosted: Fri Nov 29, 2024 7:27 pm
Hello
Is there any possibility to add an element in the dock to "eject usb devices"?
This is one of the biggest problems I have when I hide the taskbar while my Winstep docks are active. Only for this I have two elements in my dock just to unhide and hide the taskbar.
 Post subject: Re: eject usb device
PostPosted: Sat Nov 30, 2024 2:04 pm
Unfortunately there is no internal command for that.
If it helps a bit, you can replace the two internal commands in the dock for hiding and showing the taskbar with a single toggle IC (Desktop -> Hide/Show Taskbar)
PostPosted: Sat Nov 30, 2024 5:32 pm
If there was (a literal) one, it wouldn't be a very useable or even useful one. It would eject *all* USB devices at once.
That said, some sort of facility for *selectively* ejecting USB devices would probably be useful.
PostPosted: Sat Nov 30, 2024 7:17 pm
No, this is not what I want. I would like to see some elements of the right side of the taskbar permanently (like in the standard task bar). But I guess that this is not possible if using your docks.
this would be great.
But I also use e.q. veeam backup program which has an icon at the right side of the taskbar which has right mouse click functions. This I also can not use with active dock's.
PostPosted: Sun Dec 01, 2024 7:39 am
Maybe you'd find that great. In reality, it would be a total disaster for many or even most users. I might have between 4 and 8 USB devices connected at the same time, especially when I'm running Windows with 1 or 2 Linux VMs. Now I might want to unmount maybe 1 or 2 drives but need the others still - I certainly could not use that functionality. If I did, I'd have to re-mount and re-decrypt the drives that I needed to keep!
PostPosted: Sun Dec 01, 2024 8:47 am
OK, but another good option would be a possibility to eject USB devices like with the windows task bar.
PostPosted: Sun Dec 01, 2024 10:48 am
It is possible if you are NOT running Windows 11 24H2. Unfortunately from Windows 11 23H2 onwards Microsoft started changing the the way the systray/notification area works internally and broke all the work I did over the years to have a fully functional (and customizable) systray on the docks.
Under 23H2 you could still access the system tray "overflow" area from the dock, but 24H2 (which I guess is what you are running) seems to have broken it entirely.
Oh, agreed, I was thinking more in terms of an IC to popup the actual Windows 'Safely Remove Hardware' dialog. From there the user could select which drive to eject.
PostPosted: Mon Dec 02, 2024 3:44 pm
Ah yes, that would be perfectly workable. In any event, I don't imagine for one moment that all devices actually could all be ejected literally at once - at best, they'd be processed in sequence.
Oh for the joys of Win 11 - not! ;) Total rot. Can you imagine what kind of a horror story Win 12 is going to be? (If they ever get there...) :P
PostPosted: Mon Aug 18, 2025 4:06 pm
Hello
For anyone who is still interested in the topic. I found a solution which works fine. This batch file does the job
Code:
@echo off
setlocal enabledelayedexpansion
REM --- PowerShell-Skript aufrufen, um USB-Laufwerke zu listen ---
set count=0
for /f "delims=" %%A in ('powershell.exe -NoProfile -ExecutionPolicy Bypass -Command ^
    "Get-Volume | Where-Object {$_.DriveType -eq 'Removable'} | ForEach-Object { if ($_.FileSystemLabel) { Write-Output ($_.DriveLetter + ' - ' + $_.FileSystemLabel) } else { Write-Output ($_.DriveLetter + ' - <no Label>') } }"') do (
    set /a count+=1
    set "drive!count!=%%A"
    echo !count!. %%A
if %count%==0 (
    echo No USB-Device found.
    pause
    exit /b
REM --- Benutzerabfrage, welches Laufwerk ausgeworfen werden soll ---
set /p choice=Enter the number of the drive you want to eject:
if "%choice%"=="" (
    echo no number entered.
    pause
    exit /b
set "selectedDrive=!drive%choice%!"
set "selectedDriveLetter=!selectedDrive:~0,1!"
REM --- Laufwerk sicher auswerfen ---
echo trying to eject drive %selectedDriveLetter% ...
"%~dp0RemoveDrive.exe" %selectedDriveLetter%:
echo.
pause
PostPosted: Mon Aug 18, 2025 8:07 pm
Hmmm, I added a "Eject USB Device" internal command to v25.7.
Thanks for the script anyway. :)
PostPosted: Mon Aug 18, 2025 8:50 pm
Hello Jorge
the problem with your internal command is, that it does not work.
At least it does not work at my windows 11 PC. I get an error message, that my USB stick is not a removable device and I can not eject it.
But the script I use is working for me.
PostPosted: Mon Aug 18, 2025 9:23 pm
Details, Andreas, details! :D
That dialog belongs to Windows. If it doesn't work, I blame Microsoft - as usual. :D
PostPosted: Tue Aug 19, 2025 4:09 am
Sorry to say this, but if my script works fine, the problem is with your internal script.
PostPosted: Tue Aug 19, 2025 4:45 am
Ah, says he who knows not the true insides of things. My "script", if you can even call it that, simply calls that particular *Windows* dialog.
You can evoke that yourself via the Windows Run prompt (WIN+R): rundll32.exe shell32.dll,Control_RunDLL hotplug.dll
Actual "ejection" (or rather, the apparent lack of it) is performed by Microsoft's own code in hotplug.dll, which was written by them and not by me.
So I double down on blaming Microsoft. :D
PostPosted: Tue Aug 19, 2025 4:56 am
Yep, it's the true meaning of IBM - I Blame Microsoft! ;)
"Script" indeed! Thought it had to be something like that, rather than a script.
Users browsing this forum: Amazon [Bot], Majestic-12 [Bot] and 211 guests
