 Post subject: Nexus Dock doesn’t auto-hide consistently after startup
PostPosted: Thu Aug 14, 2025 8:20 am
Hi everyone,
I'm new to Winstep and just started using Nexus Dock on Windows 11. It works fine most of the time, but after a system restart, the dock occasionally stays visible and fails to auto-hide even when I hover away. I'm using the latest Nexus version, and I have auto-hide enabled.grade calculator
I couldn’t find a fix yet—tried reinstalling and toggling the auto-hide setting, but no luck.
Has anyone experienced this? Any suggestions for overcoming this on Win 11?
Thanks for any tips!
 Post subject: Re: Nexus Dock doesn’t auto-hide consistently after startup
PostPosted: Thu Aug 14, 2025 8:30 am
Two possibilities:
1. Are you showing running applications on the dock? If so, see if one of them is flashing/asking for attention (for instance, I have one here that always does that after a restart).
Just like the Windows taskbar, the dock will not auto-hide until you deal with it by bringing the flashing application to the foreground.
2. Nexus Preferences -> Behavior tab -> Auto-Hide Settings.
Is "Hide or collapse automatically only when other windows have focus" enabled?
If so, the dock will only auto-hide when you click on another window.
Users browsing this forum: Bing [Bot], Google [Bot] and 207 guests
