 Post subject: Hide workshelf
PostPosted: Thu Apr 23, 2026 4:17 am
Hi,
Is there a way to hide workshelf using a command or keyboard shortcut? I mean when I minimize all windows and desktop is showing the workshelf is visible which is normal, but is there a way to hide and show this workshelf using a command or a custom/user defined keyboard shortcut?
 Post subject: Re: Hide workshelf
PostPosted: Thu Apr 23, 2026 5:14 am
You can use Auto-hide (Shelf Properties -> Behavior) to hide the shelf - tick 'Auto-hide after a short delay'.
Modify the 'Auto-Hide Settings' to match your preferences.
I personally prefer to keep the tabs displayed when the shelf is collapsed, but you can hide those as well if you want the Shelf to disappear completely.
Users browsing this forum: Amazon [Bot], Majestic-12 [Bot] and 224 guests
