 Post subject: Passing two or more files to CMD result in double execution
PostPosted: Sun Aug 09, 2026 11:09 am
I'm a new user of the free version of Nexus v26.6.
It works well, looks great, and does almost everything I need it to.
There is one feature I'm missing, though.
When I drag and drop two or more files from Windows 11 File Explorer onto a CMD icon in the Nexus dock, the CMD is executed once for each file.
I cannot find a setting that tells Nexus to pass the files as two or more arguments at once. This is necessary because my CMD needs two or more PDF filenames to merge them into one.
Is there a way for NEXUS to send all the filenames that have been passed to my CMD at once as separate arguments?
You can check it with this small example CMD as new NEXUS dock element:
Code:
@echo off
echo Passed arguments:
echo.
set /a count=1
:loop
if "%~1"=="" goto end
echo Arg%count% = %~1
set /a count+=1
shift
goto loop
:end
PAUSE
Steps:
a) Drag and drop two or more files directly onto the CMD
and
b) Add the CMD to the Nexus dock and drag and drop the same files onto the Nexus icon
 Post subject: Re: Passing two or more files to CMD result in double execut
PostPosted: Sun Aug 09, 2026 3:09 pm
Yes, that is the current behavior.
Not currently, no.
But you do have a point, if you are dropping several files INTO a single icon then they should ALL be passed as a SINGLE argument (this would be the expected behavior), rather than being passed individually.
Let me see what I can do.
PostPosted: Sun Aug 09, 2026 4:00 pm
Thanks!
I'm not sure if there are people expecting arguments to be passed individually.
If so, it would be great to have an option - for example in the element's properties - to get the same output as if the files were passed directly to the same CMD.
PostPosted: Sun Aug 09, 2026 5:07 pm
I don't think so (or at least I hope not lol), because the normal Explorer behavior is what you originally expected, not what the Winstep application is doing now.
PostPosted: Sun Aug 09, 2026 11:48 pm
And I take that back. I implemented the code to pass multiple dropped files in a single launch, and this works fine with your script, for instance.
The problem is that most applications do not seem to accept multiple filenames in a single launch. So, if you want to open multiple text files in Notepad, for instance, by dropping them onto the Notepad shortcut in the dock, the previous method could actually accomplish this by launching multiple instances of Notepad, one for each document.
The new method launches Notepad only once and passes all the filenames as separate command-line arguments, but Notepad completely ignores every filename after the first. Most other applications seem to behave like this too - although your script handles it properly and shows each file as a separate argument.
So, in a way, the old method was actually preferable.
Therefore I think you are right: I should keep the old method as the default and add a new setting to the Item Properties dialog, something like "Launch once for multiple dropped files", which forces the new behavior for that particular item.
PostPosted: Mon Aug 10, 2026 1:35 am
Please download the latest beta from here:
viewtopic.php?p=51217#p51217
PostPosted: Mon Aug 10, 2026 10:34 am
Thank you very much for providing v26.8 (Beta 5) so quickly!
Your new feature works perfectly and meets our expectations exactly!
German translation suggestion for "Launch once for multiple dropped files"
"Nur einmal starten bei mehreren fallen gelassenen Dateien"
or
"Nur einmal starten bei mehreren hineingezogenen Dateien"
or shorter:
Replace "einmal" with "1x"
I don't know how you translate "drop" into German in other parts of your tool.
It might help if you would provide a real example in your Help section, such as
'... to merge two PDF files into one in a CMD batch file...'.
Users browsing this forum: Amazon [Bot] and 187 guests
