 Post subject: Can't Pin Brave Origin to Dock
PostPosted: Sun Aug 09, 2026 11:41 pm
Hi,
I can't pin the Brave Origin Browser to the dock. I can pin the exe from explorer, but it doesn't register with Brave Origin running in the system tray. Here's what happens when I pin it from the start menu: https://ibb.co/1JTp6hV9. Here's what happens when I try to add the program to the dock: https://ibb.co/gZxHvQTn. It's a regular Windows x86_64 program.
Regards
 Post subject: Re: Can't Pin Brave Origin to Dock
PostPosted: Mon Aug 10, 2026 1:34 am
Just to clarify what is happening: after you pin the Brave Origin EXE from Explorer, does that pinned icon launch Brave Origin normally, but then a separate task icon appears on the dock when Brave Origin is actually running?
You are running v26.6, aren't you?
Please download the latest beta from here:
viewtopic.php?p=51217#p51217
And let me know if that fixes your issues with the Brave Origin browser.
Users browsing this forum: Amazon [Bot] and 184 guests
