 Post subject: Little request regarding Always On Top.
PostPosted: Thu Aug 13, 2026 8:36 am
Certain apps such as Edge/Chrome in full screen prevent me from accessing Workshelf set on the left edge of my monitor.
Another app is FL Studio.
So, I would really appreciate if Workshelf was truly Always on Top at all times under all circumstances.
I also need a way to set a shortcut to show Workshelf. I will investigate in the settings to see if that's possible.
EDIT: I've set a shortcut (CTRL+ALT+D) to show the dock, but still doesn't show when Edge in fullscreen is focused. (game over)
Thank you.
 Post subject: Re: Little request regarding Always On Top.
PostPosted: Thu Aug 13, 2026 9:05 am
Hi, long time no talk...
As I think you know, dock and shelf activations are deliberately disabled when a full screen application is running so you don't accidentally activate the dock with a edge bump as you are about to finally kill the boss after 1,000 tries in your full screen game.
This said, there is a full screen exclusion list you can add edge and FL Studio to... that should solve the problem.
PostPosted: Thu Aug 13, 2026 9:17 am
Oh...that makes total sense. I did that and works like a charm.
Thank you!
BTW: I discovered a bug when you scroll in the exclusion apps dialog. It keeps making the fonts bigger and bigger.
PostPosted: Fri Aug 14, 2026 8:02 am
Eh? I'm unable to reproduce here (unless I am looking in the wrong place). Can you please provide more details, screenshot?
Also, what version are you running?
Users browsing this forum: Amazon [Bot], Bing [Bot] and 195 guests
