 Post subject: aus Dock löschen.
PostPosted: Fri Aug 28, 2026 10:01 am
Hi zusammen
wo stellt man das ein?
Ich will Docks Löschen nun wenn ich die rausziehen, wird nur eine kopie angelegt und ich würd es den so gerne rauslöschen.
nur über rechtsklick element Löschen gehts,
Irgent wo ne einstellung dafür??
Best regards,
Marc Senn
Windows 11 Enterprise 27H2 29671.1000 Experimental (Future Platforms)
A life without My Woman, Windows 11, Winstep Xtreme 26.8, Speedcommander 22.30 Pro and Directory Opus 13.25.3 is possible, but pointless.
 Post subject: Re: aus Dock löschen.
PostPosted: Fri Aug 28, 2026 10:11 am
This is an English‑speaking forum.
From now on, any posts written in other languages will be ignored until they are translated into English first.
Here is the English translation of what you wrote:
EynMarc wrote:
Hi everyone,
where do you set this?
I want to delete Docks, but when I pull them out, only a copy is created and I would really like to delete them that way.
It only works through right‑click → delete item.
Is there a setting for this somewhere?
Nexus support true drag & drop, so dragging items out of the dock will not delete the item like other docks usually do. In fact, if it is a file system item and you drag it into the desktop, it will create a shortcut to that item on the Windows desktop.
The proper way to delete a dock item is either through the right click context menu, as you have already discovered, or by adding a Recycle Bin module to the dock and dragging and dropping the item there. Note that dropping the item into the Windows Recycle Bin on the desktop is NOT the same and WILL NOT work.
Users browsing this forum: Amazon [Bot], Google [Bot] and 216 guests
