 Post subject: After Hibernation, Winstep will not fully load
PostPosted: Thu Jan 31, 2008 3:04 pm
On my laptop, (Vista) after resuming windows from hibernation,
the only things appearing on my desktop are 2 of 3
desktop modules, everything else is missing. I have to
click on the WS Icon in the task bar select preferences then
OK to get Winstep to fully load. Again this only happens
after hibernation, not a total restart.
Any Suggestions?
PS Any Chance of a desktop module with a wi-fi
signal strength indicator?
Thanx
PostPosted: Thu Jan 31, 2008 6:03 pm
desktop modules
Hmmm, just researched how I could potentialy solve this, but I still need more data:
1 - What are the modules that appear after comming back from hibernation (I bet they're the ones constantly updating their information)?
2 - What happens if you change to a simple theme like NeXT-OS and then hibernate and come back (the NeXT OS theme does not use layered/alpha blended windows, that's why I'm asking - could actually be a bug with Windows and layered windows).
3 - What happens if you bump the bottom screen edge after returning from hibernation (assuming you've got WorkShelf docked to the bottom of the screen)?
It's on the to-do list. :D
By the way, since you're running Vista, would you like to test the latest Winstep Xtreme 8.1 beta? Among other features, it adds 100% Vista compatibility.
If so, send me a private message here or an email to Winstep support.
 Post subject: Hibernation
PostPosted: Sun Feb 03, 2008 5:15 pm
Jorge, Thanks.
The 2 desktop modules were the clock and CPU meter,
which as you said are always updating, I would like to
check out the Bets 8 version, but cant find a link. I also believe
this problem with hibernation is caused by running in Vista aero
PS Originally purchased Tailsman Desktop a year
before I found your product. The other was
a nightmare with the shell switching problems,
and that was on XP
I really like Winstep and have turned some friend onto it.
(canI send you a screen shot of my desktop? if so what address?)
PS I am hesitant about switching themes outside of modules, because
I seem to always loose my desktop background, even though itis locked
Again Thanks
Chris.
Users browsing this forum: No registered users and 184 guests
